Cabin Overview
The Cabin Overview list provides a detailed overview of the cabin, including the occupancy and status of the cabin. The information shown changes depending on the filter entered in the Search Criteria.
Figure 12-36 Cabin Overview Show by Voyage
Table 12-5 Cabin Overview Field Definition
| Label | Definition |
Voyage |
Indicates the reservation for the voyage |
Date From |
Indicates the reservation Date From |
Date To |
Indicates the reservation Date To |
Search Cabin |
Indicates the cabin number |
Designation |
Indicates the type of reservations – guest, crew or resident |
Category |
Indicates the category of cabin |
Deck |
Indicates the deck of cabin |
Availability Status |
Indicates the availability status of the cabin |
Housekeeping Status |
Indicates the cleaning status of the cabin |
Sort Order |
Indicates the sorting of reservation to be display |
Features |
Indicates the feature of cabin |
Show all check-outs at current port |
Indicates the reservation only shows all check-outs at current port |
Display ‘letters’ in Each Reservation Box |
Indicates the options to display the cabin status in alphabetical view for each reservation grid |
From the Home tab, click Cabin Overview on the ribbon bar.
At the Search Criteria panel, enter the desired criteria and press F1 or click Search (F1).
Click the colored box (green/yellow/grey) of the cabin to preview the reservation information.
If Show By Voyage is selected, Previous Voyage and Next Voyage illuminate on the ribbon bar, allowing you to navigate to the previous or next voyage.
Select a reservation from the grid and click Change Cabin to open the Available Cabin window, allowing you to select another cabin. This feature requires user access right #557.
Figure 12-37 Available Cabin
Click Refresh on the ribbon bar to refresh the information.
Click Print to print a copy of the Cabin Overview.
