Cabin List
The Cabin List is a list view of all guest cabins with the current housekeeping and cabin status. Apart from the cabin list, it also provides a Housekeeping Status Summary and allows you to change the cabin status.
Figure 12-38 Cabin List Overview
From the Home tab, click Cabin List on the ribbon bar.
The default display of the Cabin List is all cabins. You can use the Search Criteria to filter for desired information.
To edit the Cabin Status, click Edit on the ribbon bar or double-click the cabin number.
On the Cabin form, select the Status from the drop-down list and fill in the information accordingly.
Click Save to save and exit the form.
