Movement in Cabin
The tasks are created when there is a check in, check out or cabin change. This only works when the Ferry, Enable Ferry Operation parameter is set to enabled.
Upon guest check-in, the cabin status changes from VC to OD
Upon check-out and when the Bypass Change of Cabin Clean State Upon Check-Out parameter is enabled, the status changes from:
OC, VC => VC
OD, VD => VD
With the Bypass Change of Cabin Clean State Upon Check-Out parameter disabled, the status changes from:
OC,OD,VC,VD =>VD
In the event of a cabin change, the system considers the cabin on the day before as checked out and the new cabin as checked in. In such circumstances, the system changes the earlier cabin status to VD and creates the corresponding tasks under VD status. The new cabin status then changes from VC to OC and the task under OC status is created.
