Tasks Overview
The Cabin/Location Task Overview not only provides a view of the overall cabin status, it also allows you to update the cabin clean status and the task status. It comprises the following tabs: Cabins, Public Locations, Cabin Linen Forecast and Maintenance Work Orders, with the Cabins tab being the main tab. In this window, you can search for a cabin by task status, housekeeping status, housekeeping section, deck and the total counts.
Figure 12-20 Cabin Tasks Overview
The figure shows the Cabin Tasks Overview window.
Above the Housekeeping Status Total Counts section, the Total Pending Cleaning Time (m) sums up all the pending task durations based on the search criteria and time shown in minutes.
In the Cabins tab, the cabins are shown in the grid layout with their status and number of pending tasks. See the following table for an explanation of the fields.
Figure 12-21 Pending Cabin Task
The figure shows the Pending Cabin Task display.
Table 12-1 Pending Cabin Task Labels Definition
Label Definition
Yellow
Cabin with pending task.
Red
Crash Cabin
Pink
Rush Cabin
Green
Cabin with completed task.
HKG
Indicates the port code where the tasks is generated, based on the arrival port setup in Cruise Setup.
04502-CD2
Indicates the cabin number followed by the cabin category code.
NEXT EMB: MYPEN-SGSIN
Indicates the next embarkation port and disembarkation port for the expected checked-in guest
2 Pending
Indicates the number of pending task for the cabin.
LINEN CHANGE
Indicates the cabin requires a linen change
VD
Indicates the cabin housekeeping status: VD for Vacant Dirty and OD for Occupied Dirty.
C-OUT
Indicates the passenger has checked-out from the cabin.
The system generates the cabin/location and pending tasks during the system date change or when the passenger checks out from the cabin. The topics below describe the change triggers.
