Cabin/Location Management
The Cabin/Location Management function provides an overview of the Cabin/Location tasks and enables you to add a new Housekeeping Task.
Cabin Task
The Cabin Task function in Cabin Overview function is the same as the Task Status in Task Overview screen.
Location Overview
The Location Overview provides a location overview for of all HK Tasks and Work orders. For more information, see Housekeeping.
New Housekeeping Task
Figure 31-23 New Housekeeping Tas
On the Cabin Management screen, select New Housekeeping Task.
Enter all the required information in the New HK Task screen. The fields marked with a red dot are mandatory.
Press Save to add the new task.
