Allergies Assignment
A person might be allergic to a certain food, medicine or product, and it is important to add such information to the guest/passenger record.
Figure 22-6 Allergies Assignment
Click the Allergies Assignment at the ribbon bar.
Select an account from the name/cabin field.
Check the predefined allergies type or manually enter the allergies in the Allergies Remarks field.
Click Save to save the record.
Click Close to exit the screen.
Repeat from step 1 to edit the record.
