Options
The Options menu is an area where supported hardware and devices are set up, and accessed from the Main menu. Check with your system administrator before making any changes.
General Tab
In the General Tab, you can check mark the boxes for options applicable to your operation. By default, the checkboxes are deselected.
Figure 10-171 Options Menu — General Tab
Colors
The Colors tab allows you to define a standard color scheme suitable for the operations. These colors can be easily changed by clicking the color bar and then selecting the color from the color chart.
Figure 10-172 Options Menu, Colors Tab
Hardware
In the Hardware tab, supported peripherals, printers and devices are configured. The window varies depending on the type of report printers you select. Contact Oracle Hospitality Cruise Customer Support for assistance.
Figure 10-173 Options Menu, Hardware
Video Parameters
This section defines the video format, source, and type of compression to store in the database.
Figure 10-174 Options Menu, Video Parameters
Document Scanner
This section links the type of scanner used for specific forms, for example, driver license, passport, and others.
Figure 10-175 Options Menu, Document Scanner
