Security
Function such as User Login, Passenger movement from ship to shore or vice versa, and statistic count of passengers on-board or at shore side are found under the Security menu.
Login
The Login function enables you to logout/login from current session, using either the Function key (F8) or by selecting the option from the Security menu.
