POS Discount Department
To track the respective POS Discounts usage, provide a separate Financial Department code is needed for each debit department and the code must link to a POS Sales Itemizer. The current Sales Itemizer discount department for Food, Beverage, Alcohol, and others are configured for the basic discount posting.
To separate the POS Discount amount from the regular discount, you must set up a sale itemizer separately for the POS Discount posting department.
Figure 23-5 Discount Debit Department
This figure shows the Discount Debit Department
For each Debit main department code, create a sub-department for the POS Discount sale itemizer as shown in the above figure. You must link the Guest/Crew Department Discount Department to the POS Discount Posting Department Code.
You can set up the POS Discount level individually in a guest account from the New Guest Information and/or the Edit Guest Information window, and this would determines the applicable discount rate on the guest check. The eligible discount rate for a guest is sent to POS through the Oracle Simphony when you swipe the guest board card at the outlet.
