Launching Seaware Monitor
The OHC Seaware Monitor is accessible from the OHC Launch Panel.
  1. To launch the program, double-click the OHC Seaware Monitor.
  2. In the application window, select the date range and click the Refresh button to display the activities.
    Figure 17-2 Seaware Monitor Activities
    This figure shows the Seaware Monitor Activities
    In the Statistic section,
    • The Pending status refers to the transaction that has not been sent to Seaware for processing.
    • The Successful status refers to transactions that are processed successfully and responded to by Seaware.
    • The Failed status refers to the transaction that has been processed but failed after responded to by Seaware.
