Log Based on Syn_Operation
The following status codes explain the types and details of error messages logged that allow you to extract the content into an XML file using the steps below.
Table 17-1 Syn_Operation Error Code
| Log | Description |
1 |
New reservation |
2 |
Update reservation |
3 |
Port operation |
4 |
Cargo |
5 |
Cabin operation |
6 |
Update Reservation include res_grp |
7 |
Update personal information |
To view the log details,
Double-click the failed transactions.
Click Extract.
At the confirmation prompt, click OK. This saves the transaction error to the default save folder on the client PC in an Extensive Markup Language (XML) format.
Figure 17-3 Seaware XML File Types
Error attachments are stored in the SEWLOG_XML table.
