Layout Level Details
Figure 6-1 Layout Level Details
Select a layout template that you created earlier.
Click the Add New Level button.
Enter the Layout Level Details consisting of Level Code, Level Name, Hybrid, Open Seating Capacity, Layout Image File, and Layout View.
Click Save Level to save.
Creating Layout Template
Figure 6-2 Layout Template
You can add a template, delete, save or undo the previous change made on the template. After creating the location template, add a new level for the template or define the seating zones by location.
One location can have multiple templates.
One template can have multiple layouts.
Table 6-2 Field Definition of Layout Template
| Field Name | Description |
Hybrid |
An open space for people to stand. |
Open Seating Capacity |
Defines the number of hybrid for that level. |
Seat Counts |
Total number of fixed seats for that level, display field and auto-populate whenever a new seat is created for that level. |
Layout Image File |
Attached layout for that level (image file for example .jpg, .png, .bmp, and .gif) |
Clear |
To clear the saved image for that level Layout View radio button. |
Adding Seats to Layout
The seat button toggles between both options, Insert Seat/Stop Insert Seat, when clicked.
Click Insert Seat button.
Point to the layout the location of the seat.
Go to the Seat Properties window and update the seat row, number and all other relevant information per the following:
Seat Code: Seat Row and Seat Number (auto populated).
Comments: Enter comments for that specific seat.
Zone and Type: Select Seating Zone and Seating Type.
Position X & Y: Allows you to change the seat position X & Y in the layout.
Rotation: Option to rotate the seat.
