Location Setup
Locations
Event Locations can be set up by clicking the Locations button on the ribbon bar, entering all the required information and clicking Save.
Table 6-1 Field Description of Location Details
| Field Name | Description |
Code |
A short code for the location. |
Name |
The name of the location. |
Description |
A description of the location. |
Comments |
Comments about the location. |
Deck |
Location of the deck linked to TYP_DEK |
Picture File |
Stores the file path of attached picture file. |
Availability |
Function that controls whether the location is to show in the Overview screen. |
Overlap Book |
Function that controls the system to warn when booking exceeds the maximum number specified. |
Deleting Event Location
To delete a location, select the location from the list and click the Delete button.
Locations Layout Setup
Layout Template Details
Layout Level Details
At the Setup tab, click Locations Layout Setup.
Click Add New Template to create a new template.
Enter all the information and click Save Template and then Close.
