Batch Clock-In/Clock-Out
The Batch Clock-In/Out function allows the manager to perform a batch clock-in/out for the crew on selected tasks such as fire or emergency drill, based on the parameter set in Enable Batch ClockIn/Out. Use of this function is only permissible for users granted with privilege access #4686 - Batch Clock-In/Out. You can only post the batch clock-in/out for tasks past the server time and on the current system date.
At the main window, navigate to the Schedule tab and click the Batch Clock-In/Out button from the ribbon bar.
In the Batch Change Task Clock-In/Out window, select the Department and Position from the drop-down list, and click Search.
Figure 8-24 Batch Clock-In/Out Task
At the Select Crew Members section, a list of crew matching the selection is shown. Select the names and click the double right arrow.
Select the New Task Code, Batch Clock-In/Out Data and Time range from the drop-down list.
Click OK to post the clock-in/out.
For crews whose last transaction was a clock-in, the system performs:
Clock-out with the task code that corresponds with the previous clock-in.
Clock-in with the specified task code.
Clock-out with the specified task code.
Clock-in with the task code that corresponds with (i) and the time is 1 minute after the batch clock out time.
For crews whose last transaction is a clock-out, the system perform
