Import Package Template
This function imports the package plan template exported from the Export Package Template function in the Tools application.
In the Tools Import/Export tab, select Import Package Template from the ribbon bar.
In the Import Package Template window, click Select File to browse the XML file.
Select the template you wish to import from the Selected column.
Click Import to begin import.
At the message prompt “Some of the template already exists in the DB, do you want to overwrite it?”, click Yes to continue, and then click OK to close the window.
