Export Package Template
This function duplicates the package plan template from one ship to another.
  1. At the Tools Import/Export tab, select Export Package Template from the ribbon bar.
  2. At the Export Package Template setup, select the Package Plan Template to export.
  3. Click Export and browse the location to save the XML file.
  4. Click OK when message prompts “Export of Package Template Completed.”
