Serial Port Reader
The Serial Port Reader is a tool to test the reader connection with the barcode or card reader COM port.
Figure 14-9 Serial Port Reader Setting
This figure shows the Serial Port Reader settings window
  1. Connect the device to the PC and click Serial Port Readeron the ribbon bar.
  2. In Serial Port reader window, select the Com Port, Parity, Baud Rate, Data Bit, and Stop Bit.
  3. Select the Show Result as Hex checkbox to show read results in Hexadecimal format.
  4. Click Connect. The connection indicator turns to green if the device is successfully connected.
  5. Press any button on the device to start reading a barcode. The result shown in the text field.
  6. Click Clear All Text to clear the field.
