Verify Embarkation Data
This function validates and lists all VARCHAR2, CHAR fields that
haves ASCII value of more than 127. For example: €, ‡, Œ, Ž, ¢, ©,
®. The verification validates the reservation fields used in the Advanced
Quick Check In application such as CAB, RES, CRD, SEC, SIG,
USR, UXP, VIS_BLOB, VIS_TEXT.
In the Tools window, select Verify Embarkation Data from the ribbon bar.
In the Verify Embarkation Data window, select the relevant options and Include Check In if you want to include check-ins.
Click Verify Data to proceed with verification. Below are the sample results shown in the verification window:
The Non-ASCII code size less than 18 characters will have status as OK.
The Non-ASCII code size that are more than 18 will have status shown as Not OK and listed with “There is potential x problem(s) found, please review the log file VERIFYDATA_yyymmdd.txt”.
Figure 14-10 Verify Embarkation Data
