Workers in Workgroup
The Worker in Workgroup is a sub-category of Work Order Type,
where workers are grouped according to their skills and expertise.
- Select Workers in Workgroup from the Maintenance Setup menu.
- Right-click and select Add Group.
- Enter a code, description, and comments.
- Click Apply to save.
- Right-click on the newly created code and select Add Worker.
- Select to Assign by Crew or Assign by Operation Position, then select the crew name or position from the Name field.
- Enter a description and click Apply to save.
- Click OK to close the window.
