Adding an Event
  1. From the Itinerary Setup drop-down menu, select Events.
  2. In the All Events section, right-click and select Add Event Type.
  3. Enter a short code and description in the Description field and then click OK.
  4. Select the Event Type, then right-click and select Add Event.
  5. In the Details section, enter the event number, title, and description of the event.
  6. Select a Location, Type, and Ticket from the drop-down list.
  7. In the Demographics section, enter the Age Range and select the Family Status, Marital Status, Gender, and Age Restriction from the drop-down list.
  8. Click OK to save the entry.
