Comments Overview
The Comments Overview allows you to view and edit all comments entered in the Crew Handling function, as well as add new comments.
Figure 7-4 Comments Overview Window
This figure shows the Comments Overview Window
  1. From the Overview menu, select Comments Overview.
  2. In the Selection Criteria, select from the available filters for information to display, and click Refresh.
  3. Information matching the selection appears in the Comment section. To view comments, select a comment.
See Comments Tab section on how to add or remove a comment.
