Flights Overview
This function enables you to set up arrival or departure flights,
which allows you to plan your resources and organize ground transfers
for crew and passengers where necessary. To access the function, select Flights Overview from the Overview menu.
Figure 7-5 Flight Overview Window
Adding / Removing Flight Information
- In the Flight Dates section, right-click and select Add Flight.
- In the Flight Information section, enter all the necessary information and click OK to save.
- To remove flight information, select and right-click the Flight Number and select Remove Flight.
