Crew Handling
Search Panel
The Search Panel function is a reservation look up by status in a tab view — Check In, Check Out, Expected, Canceled and No Show from the Crew Handling window.
Search Using the Search Panel
At the Search Panel, select the Status tab.
You can select an alphabet corresponding to the last name of the reservation or select ALL to list all reservations in alphabetical order.
You can further narrow down the search using either the crew name, document number, or cabin number and date.
