Login
Change Password
From the Security Menu, select Change Password.
Enter the new password, confirm the password, and click Apply.
At the Password Successfully Changed prompt, click OK.
User Logfile
The User Logfile records all transactions performed by users by date, and by time order. Use the available filters such as by user, type of activities, date, time, or workstation to retrieve log information. The transaction logs are printable and exportable to a supported file format.
Gangway Logfile
The Gangway Logfile records the gangway movement for all passengers going ashore or coming onboard. Use Search to find information by location, movement directions, type of passengers, date, time, cabin number, and name. Retrieved information is available for printing or exporting in a supported file format.
Count Onboard/Shoreside
The Count Onboard/Shoreside shows the security count of total crews and the number of crews onboard or at shoreside. The counts are displayed by type of crews.
Figure 7-130 Count Onboard/Shoreside
To reset the count, click Reset Security. The messages prompt varies on each reset.
Guests/Crew Onboard
The Guest/Crew Onboard lists all crew members onboard, with the Last Coming On-Board status shown when selecting the crew’s name.
Clicking the Go Ashore / Go Onboard.
Clicking the Gangway Log to open the Gangway movement log.
