Quick Posting Status
The Quick Posting Status Enable/Disable function sets the
account posting status by batch.
Figure 7-27 Enable/Disable Posting Selection
- From the Quick Functions File menu, select Quick Posting Status Enable/Disable from the drop-down menu.
- In the Enable/Disable Posting by Selection window, select the amount from the drop-down list or click Advanced to select multiple accounts.
- Insert a reason in the Reason field.
- Select the Allow manual postings checkbox if manual posting is allowed for Disabled accounts.
- Select one of the options: Enable or Disable the account.
