Violation Overview
It is mandatory for crew to complete certain courses/certificates related to their safety number but not all are on the eligible operational position list, or vice versa. In the Violation Overview window, you can filter and view the violation, if any. You must have access right #4655 — Access to Violation Overview granted in order to access this function.
Figure 7-122 Safety Violation Overview
This figure shows the Safety Violation Overview
You can select only one of the following violations from the drop-down list:
  1. Operational Requirement Violation: Crew with Safety number assigned but Operational Position not linked to an assigned Safety Number.
  2. Qualification Requirement Violation: Crew with Safety number assigned but does not fulfil the primary/substitution course and certificate required for that safety number.
  3. Both: Crew that violates both of the above requirements.
To view the violation, select Violation Type from the drop-down list.
