Removing Group Delegate
The Remove Group Member removes the selected delegate from
the group profile. This process deletes the guest from the event group
attendees in Event Booking.
- Search for the group profile from Profiles Search function on the left pane.
- Select the profile and then navigate to the Delegates tab.
- Select the delegate to remove and click Remove Group Member from the ribbon bar.
