Check In Function
Guest joining the cruise are required to checked-in to the system prior to boarding, and these reservations are categorized under the Expected tab.
  1. Retrieve the reservation from the Search Panel, Expected tab and then click Check-In.
  2. At the Check In prompt, click Yes to check in the reservation and print keycard at the same time.
