Check Out Function
At the end of the voyage, you must check-out all the guest accounts from the system. This is to ensure that all accounts are in balance before performing a System Cruise Change.
  1. Retrieve the reservation from the Search Pane, Check In tab and then click Check Out.
  2. At the Check Out prompt, select Yes to check out the reservation.
  3. If the account is unbalanced, the system prompts for an invoice to be settled before proceeding. Click OK to return to the guest account.
See Pay Invoice section for steps to settle an account.
