Checking in Group Account
To route group members charges to the Group Account, you must first check-in the group account.
  1. From the Expected tab of the Search panel, search for the group account.
  2. Select the account and click the Check In button.
  3. Select Yes at the Check-In Group prompt, and then click OK at the confirmation prompt.
