Checking Out Group Account
A group account can only be checked out when the invoice is balanced.
  1. Retrieve the group account from the Search panel, Check Out tab and then click the Check Out button.
  2. At the Check Out prompt, select Yes to check out the account.
  3. If the account is unbalanced, the system prompts for the invoice to be settled before proceeding. Click OK to return to the guest account.
See Pay Invoice section for steps to settle an account.
