Guest/Crew Shoreside
This function is the same as Guest/Crew Onboard and only displays passengers that are ashore.
You can change the status by:
  1. Clicking Go Onboard to set the selected passenger status from Ashore to Onboard.
  2. Clicking Gangway Log to open the Gangway movement log.
