Port/Visa Requirement
The Port/Visa requirements function enables you to restrict passengers/crew that has travel restrictions on their travel document from going ashore on port day. Once set up, the system prompts a notification window when a restricted passenger’s passport/travel document is swiped at the Gangway.
From the Security menu, select Port/Visa Requirement.
Click Add New, enter the Date/Time From/To field, and select the Port from the drop-down list.
Select whether the restriction applies to Pax and Crew, Pax or Crew only.
In the Conditions Setup section, select the Nationality and Visa Type from the drop-down list, and click Save.
At the Insert Confirmation prompt, select Yes to confirm and then click Close to exit.
Immigration Filtering
This function enables you to define the guest or crew to exclude from the Immigration Inspection.
Figure 10-177 Immigration Filtering
From the Security menu, select Immigration Filtering.
In the General section, select the Account, select Embarkation/Disembarkation, and click Search.
Select the Document Type, select the Nationality, then click Search to further filter the guest list.
On the Guest List, select the passenger to add or exclude from immigration gate and then click the respective button.
If Guest has “Switch to Crew in Manifest” set up, then the guest account appears under Account Type “Crew”. If Crew has “Switch to Passenger in Manifest” set up, then the Crew account appears under Account Type “Guest”. -
Excluded passengers have a check mark in the Exclude column.
