Opening a Cashier Session
- From the Cashier menu, select Cashier Session from the drop-down list.
- Click the plus (+) key to expand
the Cashier container, right-click on the user name, and select one of the following options:
- Open Session (Empty) — This function opens a cashier session for the selected shift.
- Open Session (Linked) — This function opens a cashier session with previous closing balances being brought forward as the Opening Amount.
- In the Name field, select the Session code from the drop-down list.
- Enter the Opening Amount for the respective department code and then click Apply.
