Closing a Cashier Session
  1. From the Cashier menu, select Cashier Session from the drop-down list.
  2. Expand the Cashier container, right-click on the session, and select one of the following options:
    • Close Session (Balance) — This function closes the cashier session by automatically filling in the amount in the Closing Amount column.
    • Close Session (Empty) — This function requires you to input the value in the Column Amount column.
  3. Click Apply to save the value entered.
  4. When there is discrepancy on the value, the system prompts for further action. Select Yes to set the session status to Discrepancy, allowing you to further research and resolve the discrepancy.
Figure 10-169 Cashier Closing Discrepancy
This figure shows the Cashier Closing Discrepancy
