Resolving Imbalance Cashier Session
  1. From the Cashier menu, select Cashier Session from the drop-down list.
  2. Expand the Session container, right-click on the session, and select Close Session (Balance).
  3. Enter the correct value in the Accepted Amount column and click Apply to save the amount and print the final closing report.
