Posting Status
The Posting Status is a function that assists you in managing cash-paying guests or guests who may have exceeded their credit limit. This function enables/disables the posting from flowing through to the account.
Disabling a Posting- Retrieve the reservation from the Search panel and then click Posting Status in the Guest Info tab.
- Enter the reason to disable the posting when prompted, either by selecting a predefined reason from the drop-down list or by manually inserting them.
- If you select Allow manual postings, this only disables postings from the interfaces. You can still perform manual posting within the Guest Handling function.
- Click OK to set the posting status for the account to No or Manual.
Figure 10-23 Posting Status (No or Manual)
Enabling Posting
Retrieve the reservation from the Search panel and then click Posting Status in Guest Info tab.
The system prompts for a response to accept the postings. Selecting Yes resets the Posting status to allowed, whereas No retains the Posting status unchanged.
