Creating a Party
This function manages and identifies a small number of persons travelling together who do not necessarily share the same cabin. In addition to identification purposes, the person responsible for payment of accounts or main contact liaison can be made as the “primary” passenger.
  1. Search the reservations in Search panel.
  2. Use the CTRL+ key to select the names that make up a party.
  3. Click Create Party under the Guest Info tab.
  4. The system updates the guest of the same party with Shore-Res ID.
Figure 10-24 Party Identifier
This figure shows the Party Identifier
Showing a Party
To view a list of travel companions within a party, click the Show Party button.
