Quick Messages
The Quick Message function allows you to send messages to a group of passengers or individually using the Advanced Selection.
  1. From the Cashier File menu, select the Quick Messages option.
  2. In the Quick Message window, click Advanced to open the Multiple Account Selection window.
  3. In the Multiple Accounts Selection window, select the Status, Account Type from the drop-down list.
  4. Select the account name from the Non Selected Accounts pane, and then click Add to add the account singly or Add All> to add all accounts listed or use the Criteria Add>, and click OK to return to Quick Message window.
  5. In the Quick Message window, enter the Sender’s name and message content.
  6. Select the Delivery Mode and Acknowledge mode from the drop-down list, and click OK to save.
  7. The system places a check mark in the guest account in Guest Handling, Message tab as an indicator for undelivered messages.
    Figure 10-162 Quick Message Form
    This figure shows the Quick Message Form
