Removing from Group
This function removes guests from an existing group and converts their reservation to an individual reservation.
Removing a guest from group
- Search the guest name using the Search panel.
- Mark the reservation(s) and then click Remove from Group.
- The system prompts for a response to remove selected guest(s) from the group. Click Yes to proceed and the group name is removed from the Guest Info, Member of Group field.
