Renew Reservation Function
You can renew a reservation of a checked-out guest using
the guest historical data instead of creating a reservation.
- Navigate to the Check Out tab in Search panel.
- By default, the date is set to System Date. Change the date to the passenger check-out date.
- Enter the guest last name or use the alphabets tab to search. Selecting the ALL tab will list all passengers departed on the date specified.
- Click the Re-New Reservation at the Guest Handling window.
- At the New Guest Reservation prompt, select Yes to renew the reservation.
- Click Edit Information to change the expected arrival date, if required.
