Searching For Guest
  1. To locate a guest’s reservations, in the Search panel, select the Status tab and then select the first letter in the guest’s last name. If you select ALL, all reservations appear in alphabetical order.
  2. You can narrow down your search using the guest name, document number, or cabin number and date.
