Retail Setup
Retail Items, Groups, and Lines
In the Retail Group, you can define the type of Retail Items available at the Spa. The Retail Group is used to identify the Retail Line such as the manufacturer or the sub-type of item.
The Retail Groups are kept within the Retail Setup menu.
To add a new group, right-click the tree view and select Add New from the option menu.
Enter the Code, Description and Comments.
Click OK.
Select the group to delete from the tree view.
Right-click and select Remove from the context menu.
Select the group from the tree view.
Click Update.
General – Displays General Information about each Retail Item.
Pricing & Sales – Displays Pricing Period information.
Bar Codes – Displays all available Bar Codes assigned to each Retail Item.
Table 5-2 Field description of options in Retail Lines Setup Screen
| Option | Description |
Group |
The Retail Group to which this item belongs. |
Shore Code |
The SKU number for this item. Based on recent discussion, this field will expand so that an unlimited number of SKU’s can be defined for an item. |
MMS Code |
MMS or external F&B system Item Code (Crunch Time). |
Active |
If this field is checked, then the item is available for sale. |
Name |
The short name of the item. |
Descriptions |
A longer name or description for the item. |
Line |
The Retail Line for this item. |
Prepaid Itemizer |
The Prepaid posting suffix for this item (For Prepaid Retail). Items imported using the Data Import module. |
Table 5-3 Field description of Options in Retail Lines Setup – Bar Codes Tab
Bar Code ID |
Multiple Bar Codes associated with this item. |
Table 5-4 Field description of options in Retails Lines Setup – Pricing and Sales Tab
From Date |
The starting date for a new Price. |
To Date |
The ending date for a new Price. |
Price |
The price to apply for the period specified from The Starting Date to the Ending Date. |
Price Grid |
A list of all active prices for this item. The item must always have a price for all dates from today through Dec 31, 2099. |
