Disable Cards
The Disable Cards functionality allows you to deactivate all active cards linked to a selected profile. Once disabled, these cards cannot be used within the system or for stateroom access, if applicable.
To disable profile’s cards:
  1. Click the profile’s Disable Card button.
    A confirmation prompt appears:
    Disable Card confirmation prompt
  2. Select Disable to confirm disabling the active cards.
  3. Upon successful completion, the system displays a message: All cards have been disabled.
