Preface
The Mustering application is a front-end application that radically transform emergency passenger-handling time by leveraging cutting edge electronic hand-held devices.
With the ability to track passengers and crew member in real-time, it empowers cruise operators to manage the emergency process more efficiently while keeping officer on the bridge fully updated on the process. This powerful application reduces manual errors in passenger and crew registration, speeding the process by 50% with the use of Radio Frequency Identification (RFID) to scan the boardcard.
Audience
This document is intended for application specialist, IT Officers and end-users of Oracle Hospitality Cruise Shipboard Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
https://iccp.custhelp.com
When contacting Customer Support, please provide the following:
  • Product version and program/module name
  • Functional and technical description of the problem (include business impact)
  • Detailed step-by-step instructions to re-create
  • Exact error message received
  • Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
Date Description of Change
October 2025
Initial publication.
February 2026
Added content for Gateway Security - Gangway/Tender functionalities.
March 2026
Added new features in Gangway/Tender: Managerial Acknowledgement - RFID, Disable Profile Cards and Gangway/Tender Statistic Counts.
May 2026
  • Updated the Tab: Search topic for search using RFID card and bar-code scanner.
  • Updated Note: Check-in validation
June 2026 Updated sections - Search and Register a Profile and Search and Unregister a Profile.
