Accessing WPF Security
The WPF Security login window can display the type of Gate and Traffic direction according to the ships operational needs. This is determined by the Exit Application Without Prompt Password and Gangway Location Functionality parameters.
  1. Begin the WPF Security application and at the Gate Settings dialog box, select the type of Gate, Traffic Direction, and Gate Location.
    Figure 19-2 WPF Security Gate Settings
    This figure shows the available Gate Settings options at login.
    Table 19-2 Gate Settings Type
    Gate Type/Direction Description
    Gangway
    The Gangway gate is used by passengers and crew when boarding/alighting the ship. The system maintains a running count of passengers and crew that are currently onboard and at shore side.
    Internal Gate
    The Internal Gate is used by Department Head/Training Manager to monitor the crew training attendance and movements in restricted area or shore duty. The in/out entries through the gate are updated except the shipboard status.
    Immigration Gate
    The Immigration Gate is used to facilitate the immigration process by swiping the passenger’s board card in and out for Immigration inspections. The Immigration information is updated except for shipboard status.
    Both Way
    Used for passengers and crew going ashore and coming on board.
    Outwards
    Used for passengers and crew going ashore only.
    Inward
    Used for passengers and crew coming onboard only.
  2. Click OK to access the main menu.
  3. At the Login prompt, enter the user name and password or click Exit to access the Main menu.
  4. The selected gate, traffic direction and location appear below the toolbar of the main window. Clicking the Close Program prompts a Security Logon dialog box. You must enter your login credential before you can close the program. You can disable the dialog box by setting the Exit Application Without Prompt Password=1 parameter.
    Figure 19-3 WPF Security Toolbar
    This figure shows the toolbar menu options in WPF Security module.
Navigating through WPF Security Main Functions
As the program predominantly records passenger movement through the gangway, the functionality in this program is scaled down to minimize the queue from building up. The functions in this module are a Refresh Count, Gangway Log, Visitor and Accessibility Handling, Immigration Gate handling, and others.
Figure 19-4 WPF Security Main Functions
This figure shows the main functions of WPF Security, with the total guest/crew count and movement activity.
Table 19-3 Field Description of WPF Security Main Functions
Function Description
Refresh Count
Recalculates and updates the total counts of the Account Statistics Board.
Gangway Log
Starts the Gangway Log window, which allows the Security Officer to view or search the gangway activities when necessary.
Visitor
Starts the Visitor window and enables the Security Officer to enter the visitor’s information, produce a visitor card, and track the visitor onboard/ashore status.
Accessibility
Allows the Security Officer to assign an accessibility status for passenger with disabilities who comes onboard.
Take Picture
Allows the Security Officer to take the picture and store the picture of a selected account in the system.
Close Program
Closes the WPF Security program.
Account Status Board
Onboard
Total Passenger/Crew/Resident currently on-board the ship.
Shoreside
Total Passenger/Crew/Resident currently at shore.
Overnight Tour
Total Passenger/Crew/Resident currently on shore for overnight tour, which includes Crew accompanying passengers for overnight tour.
Expected
Total number of Passengers/Crew/Residents expected to check in today.
Disembarked
Total Passenger/Crew/Resident disembarked today.
Disembarking
Total PassengersCrew/Residents expected to disembark today.
Visitor Onboard
Total number of Visitors currently onboard.
Information Board
Onboard / Ashore
The Onboard or Ashore Information board shows the account information by name, sex, nationality, photo, last event log, and other information when someone goes onboard from shoreside. Double clicking the board will show the account, allowing the Security Officer to search and change account status from onboard to ashore.
Gangway History Activity
Displays the last 10 movement activities with account name and photo.
Status Bar
Ship
Current Ship’s name.
Sys Date
Current Ship’s SPMS system date.
PC
PC name of current gangway workstation.
DSN
SPMS Database name.
Reader
Card reader device currently connected to the gangway workstation.
CO Guest Enabled
Denotes “Gangway”, “AutoCheckOutPax” parameter is enabled, allowing you to check-out a passenger account by swiping the board card.
CO Crew Enabled
Denotes “Gangway”, “AutoCheckOutCrw” parameter is enabled, allowing you to check-out a crew account by swiping the board card.
Light bulb image
Database connectivity status. Green denotes online, and Red denotes offline.
