Onboard/Ashore Denied Handling
There are reasons the passenger or a crew is denied from boarding or leaving for shore, and below are examples.
Travel document not collected when disembarking.
Account has an Open Balance.
Passenger or crew is denied to go ashore or onboard due to safety reason, port regulations, and others.
A visitor is denied to go onboard.
In the following section, when the disembarking passenger/crew swipes the board card through the MSR, the system sounds an alert and prompts a dialog box. Click Yes to override the onboard status. All of the functions listed below are triggered by the parameters defined in the Administration module. See Parameters section for list of available parameters.
Document Return Handling
At the end of the cruise, disembarking passengers must collect their travel documents from the Front Desk before leaving the ship. An alert message appears for the Security Officer as a reminder to passengers to collect their travel document before final disembarkation. See the following image:
Figure 19-6 Document Return Notification Prompt
Open Balance Handling
Similar to Document Return Handling, the system prompts an alert when a disembarking passenger’s account has an open balance with the balance amount indicated on the dialog box.
Figure 19-7 Open Balance Notification
Ashore Deny List Handling
This alert appears when passengers or crew are listed on the denied list in Management, Deny Ashore List. You can add a reason why they are denied to go ashore in the comment field. Refer to Management User Guide, Ashore Deny List to setup the list.
Figure 19-8 Ashore Denied Notification
Additionally, when a crew member is given a disciplinary action, the individual can be denied permission to go ashore based on the period indicated in the disciplinary form in the Crew Handling, Effect/Warning tab, Warning form.
Onboarding Denied List
Figure 19-9 Onboard Denied Notification
There are occasions when passengers, crew or visitors are denied to go onboard the ship. This is could be due to invalid travel document, the assigned board card has expired, or assigned to shore duty.
Alerts are defined in the passenger/crew account in Management, Edit Guest Information, Deny Reason or the Deny Boarding field. Refer to Management User Guide, Guest Handling, Edit Information for further details.
Security Alert Handling
Figure 19-10 Security Alert Notification
The Security Alert handling notifies the Security Officer according to the potential security breach defined in Administration, Security Alert Setup, enabling security personnel to act according to the ship’s policy. For the following example, a minor below x age is not permitted to go ashore without a guardian, and the alert is set off when the minor swipes his/her card on the MSR.
