Rate Management
Promotion Codes
To fetch offers from a PTS system while creating reservations, you must create promotion codes in OPERA Cloud. These promotions must have the same information (code, start and end dates) as the existing offers in the corresponding gaming system.
These promotions will later be redeemed in your PTS system at guest check-out via the Comp Posting operation. The promotion will automatically route from the guest's folio to a comp window when the reservation is created.
For details on creating promotion codes in OPERA Cloud, refer to Configuring Promotion Codes in the OPERA Cloud Services documentation.
