Installation Steps
You must have the connectivity agent file (this is normally named oic_connectivity_agent.zip) and install it in your on-premise environment. The connectivity agent is also associated with what is called “agent group identifier” and OIC URL. The connectivity agent must also authenticate itself, which requires you to have the agent’s credentials. Reach out to your Oracle contact to get the connectivity agent file, your agent group identifier, your OIC URL, and your agent's respective credentials. You can install the agent on up to two separate environments for redundancy. To do this, repeat the same steps in both environments.
Parent topic: OPERA Cloud Connectivity Agent
