DVMs for Light & Wonder
The below DVM values are for reference only and can vary by property.
Membership Level
This DVM will convert the Membership Levels codes in OPERA Cloud into the Light & Wonder Ranking Levels codes (and vice-versa).
OPERA Cloud Code: This is the Membership Level code that you previously created.
External Value: This is the Ranking Code in Light & Wonder that corresponds to the OPERA Cloud Membership Level code.
External > OPERA Cloud: Select this option to translate these values for messages received in OPERA Cloud.
OPERA Cloud > External: Select this option to translate these values for messages being sent out by OPERA Cloud.
Table 7-34 Membership Level
OPERA Cloud Code | External Value (aka Light & Wonder CMP) | External > OPERA Cloud | OPERA Cloud > External |
LW10 |
10 |
LW40 |
40 |
LW50 |
50 |
Document Type
This DVM will convert the Document Type used in OPERA Cloud to the Identity type used within Light & Wonder (and vice-versa).
OPERA Cloud Code: This is the Document Type code that you previously created.
External Value: This is the Light & Wonder identity type that corresponds to the OPERA Cloud Document Type.
OPERA Cloud > External: Select this option to translate these values for messages being sent by OPERA Cloud.
Table 7-35 Document Type
BIRTH |
Birth Certificate |
DL |
Driver’s License |
SSN |
SSN |
Address Type
This DVM will convert the Address Type used in OPERA Cloud with the Address Type used in within Light & Wonder (and vice-versa).
OPERA Cloud Code: This is the Address Type that exists in OPERA Cloud.
External Value: This is the Address Type in Light & Wonder that corresponds to the OPERA Cloud Address Type code.
External > OPERA Cloud: Select this option to translate these values for messages received by OPERA Cloud.
Table 7-36 Address Type
HOME |
Home |
OTHER |
Alternate |
Phone Type
This DVM converts the Phone Type used in OPERA Cloud with the Phone Type used in Light & Wonder (and vice-versa).
OPERA Cloud Code: This is the Phone Type that exists in OPERA Cloud.
External Value: This is the Phone Type in Light & Wonder that corresponds to the OPERA Cloud Phone Type code. Use "E_" prefix for Email types.
Table 7-37 Phone Type
OPERA Cloud Code | External Value (aka Light & Wonder CMP) | External > OPERA Cloud | OPERA Cloud > External Cloud |
BUSINESS |
Business |
E_Home |
HOME |
Home |
WORK |
E_Business |
Gender
This DVM converts the Gender Code used in OPERA Cloud with the Gender Code used in Light & Wonder (and vice-versa).
OPERA Cloud Code: This is the Gender Code that exists in OPERA Cloud.
External Value: This is the Gender Code in Light & Wonder that corresponds to the OPERA Cloud Gender code.
Table 7-38 Gender
F |
FEMALE |
M |
MALE |
U |
UNKNOWN |
Parent topic: Light & Wonder CMP
